Home Menu
Site Navigation
User Tag List
Reply
Thread Tools Rate Thread Display Modes
Old 02-07-2005, 08:49 PM #1
24runners's Avatar
24runners 24runners is offline
Member
24runners is on a distinguished road
Member
24runners's Avatar
how to keep the fog lights on with high beams
If anyone is interested in keeping their fog lights on with the high beams...all you have to do is ground the pin shown in the pic below.
Grounding this wire will make your fogs stay on with high beam...but makes the switch on the stalk non-functional ;) I dont care, if my lights are on...i want my fogs to be on...and stay on with high beams...I never have a reason to turn them off.
They will still turn OFF when you turn your lights off. But if your lights are on, then so are the fogs ;)
However, you can wire this to a factory style switch (i will do this) if you want to be able to turn this feature off (thanks to iForce for the part number)
Switch Part #: 84160-04010 (~$64 US or $80.38CDN)
Connector Part #: 90980-11090 (~$3.38 US or $4.25CDN) -- from this thread
that way, when the switch is off, everything works as it does from the factory....then you can hit the switch if you want the fogs on with your high beams
this is a very SIMPLE mod, VERY EASILY reversable (just take off the wire), and is NOT a complicated major electrical modification....no splicing or anything, just ground one pin of the fog light relay...there is no danger at all...what would happen? the wire might GROUND OUT?! uhhh...since thats what you are doing in the first place there is no danger!
how to keep the fog lights on with high beams-foglightmod-jpg
__________________
Doug M. -= My Website - Pics =-
1996 4Runner SR5 4x4 TRD Supercharged - sold
1994 Supra SP57 Single Turbo SPAuto - sold
2005 4Runner Sport V8 4x4 (Titanium Metallic)
Mechanical: 4.7L 32v DOHC V8 SFI Engine w/VVT-i (270hp) | 5 Speed ECT Auto | Torsen Locking Center Differential | Full Time 4WD | Down-Hill Assist Control | Tow Package | Hill-Start Assist Control | X-REAS Sport Enhancement Suspension | Front 13" & Rear Disc Brakes | Safety: Vehicle Stability Ctrl w/Traction Ctrl | Anti-Lock Brakes w/Brake Assist & EBD | Tire Pressure Monitoring System | Convenience: Light Gray Leather (sooooft) | DD Cargo | JBL Synthesis 10 speaker w/ Rear Seat Audio w/wireless remote | DRLs | Power Moonroof | Modifications: Rear reflector/light mod | '02 Sport Skid Plate | Gentex AutoDimming Mirror w/ compass | K&N Air Filter | Metal Door Sill Plates (Burtman Industries) | 5800K Headlights/Fogs (on with high beams) | VVT-i grille emblem | TRD Auto Shift Knob | Toyota All-Weather Floor Mats | 20" Enkei's | Muth Signal Mirrors | TRD Exhaust | Driver's Side Handle | pen/coin holders | Japanese smoked tail lights | Limited Gauges | Japanese Headlights | Xtec 5k HIDs
24runners is offline   Reply With QuoteReply With Quote
Old 02-08-2005, 01:19 AM #2
Hitman's Avatar
Hitman Hitman is offline
Member
Hitman is on a distinguished road
Member
Hitman's Avatar
That is an interesting mod, but there is a better way to do it.
If you supply the factory switch with power from the parking light circuit, you will be able to control the fog lights from the factory fog light switch as usual, but they will remain on with the hibeams on as well. Or you can turn the fog lights on without using the headlights, as long as your parking lights are on.
It's as simply as supplying the fog light switch with power from the parking lamp circuit.
If you leave your headlights on (and foglights), everything will still turn off with the auto-off headlight feature.
__________________
2004 Sport 4x4 Galactic Gray
Hitman is offline   Reply With QuoteReply With Quote
Old 02-08-2005, 01:33 AM #3
24runners's Avatar
Member
Member
24runners's Avatar
thats another good way without the extra switch...nice to know
where do you tap into the factory switch?
is the wiring easy to get to?
I think i might just leave it grounded all the time....
If my lights are on, I want all of them to be on...I cant think of a time I'd want to have my lights on without the fogs on.
__________________
Old 02-08-2005, 01:37 AM #4
Hitman's Avatar
Member
Member
Hitman's Avatar
I haven't done this to my 4Runner yet, but I have done it with several of my past vehicles.
I'm planning on doing it soon, so I'll post a write-up for anyone else who would like to do it too. It should be as easy as locating the wire under the dash (near the steering column) and tapping 12V from the parking lamp circuit to the control side of the circuit.
Piece of cake!
__________________
Old 02-08-2005, 03:41 AM #5
iFORCE's Avatar
iFORCE iFORCE is offline
Senior Member
iFORCE is on a distinguished road
Senior Member
iFORCE's Avatar
Hitman - i see... and that's why you need the wiring diagram....
24runners - your welcome.
__________________
Black 2003 4Runner Limited V8 4WD
(Canadian Edition)
- TRD High Performace Air Filter
- TRD Cat-Back Exhaust
- 25% Front Tint / 15% Rear Tint
- Bridgestone Dueler Revo A/T
- Projector Foglights w/ 4300K HID
- Black JDM style Taillights
- 2006 Projector Headlights w/ 4300k HID LINK
- Custom Rear Fog Lights w/ Switch - LINK
Pictures on My Website
iFORCE is offline   Reply With QuoteReply With Quote
Old 02-10-2005, 03:41 PM #6
24runners's Avatar
Member
Member
24runners's Avatar
posting a better pic is really the only thing I can do (the other one was with my cell phone)
standing at the driver's side wheel well, ground the top right pin of the fog light relay (the pins make a "T")
You can ground it to the battery terminal or to the ground screw right there next to the fuse box.
You dont have to use a wire that long *haha* thats just what I was using to make sure it worked properly.
All this does is prevent the fogs from getting the "turn off" signal when the high beams are turned on...very simple...try it...if you dont like it (i have no idea why you wouldnt) you can always just pull the wire out
how to keep the fog lights on with high beams-fogpic-jpg
__________________
Old 02-10-2005, 04:22 PM #7
kdx2000's Avatar
kdx2000 kdx2000 is offline
Member
kdx2000 is an unknown quantity at this point
Member
kdx2000's Avatar
Will this work on a 99' Limited? Just curious.
Thanks.
99' Limited Desert Dune
kdx2000 is offline   Reply With QuoteReply With Quote
Old 02-10-2005, 09:30 PM #8
24runners's Avatar
Member
Member
24runners's Avatar
Quote:
Thanks.
This will work on most any car. Just find the pin that gets ground on low and nothing on high...after you rule out any pins that get voltage at any time.
By grounding that pin, it no longer loses the ground when the high beams come on, therefore, keeping the fogs on
__________________
Old 02-13-2005, 12:06 PM #9
KMX3060's Avatar
KMX3060 KMX3060 is offline
Member
KMX3060 is on a distinguished road
Member
KMX3060's Avatar
I'm curious as to why Toyota did not want the fog lights on with the high beams. Is it possible that together the combination would draw too many amps from the alternator?
Some people who put in HID lights must install relays to avoid burning up the wiring harness and a higher output alternator so they don't drain the battery while they are on.
Anyone know what the output is of the standard alternator?
What is the wattage of the high beams and the fog lights?
Brian
__________________
2005 Sport V-8 4X4
Natural White
JBL
Line upon Line, Line upon Line,
Precept upon Precept, Precept upon Precept,
Here a Little, There a Little
KMX3060 is offline   Reply With QuoteReply With Quote
Old 02-13-2005, 01:09 PM #10
jlb jlb is offline
Member
jlb is an unknown quantity at this point
jlb jlb is offline
Member
Quote:
It has more to do with the fact that many states have provisions in their motor vehicle code that require the fog lights to switch off when the high beams are selected.
In addition if you think about it "fog lights" are supposed to to increase visibility through rain, fog and snow. They do this by producing a short, wide & low beam pattern which reduces light reflected back at the driver. As far as the manufacturer is concerned why would you need this with the high beams?
jlb is offline   Reply With QuoteReply With Quote
Old 02-13-2005, 02:46 PM #11
24runners's Avatar
Member
Member
24runners's Avatar
yes...the factory doesnt see a need for 'fog lights' on with your high beams...if you need the fog lights for fog, then you wouldnt have your high beams on anyway
plus, some places might have a low stating how MANY lights you can have on the front legally....but if I have my high beams on, NO ONE should be in front of me...so no one will see if my fogs on or not
the whole purpose of this is to give me THE MOST light when my highbeams are on (like to help see deer on dark 2-lane roads in the middle of the night)
__________________
Old 02-13-2005, 03:06 PM #12
Case_TR4 Case_TR4 is offline
Junior Member
Case_TR4 is an unknown quantity at this point
Junior Member
I tried doing this mod, but it did not work? I pulled the relay and wrapped one end of the wire around the flat pin you indicated then ran it out to the same spot you had yours to ground it, but it did not come on when I tested using my high beams. Any ideas why?
Case_TR4 is offline   Reply With QuoteReply With Quote
Old 02-13-2005, 05:59 PM #13
24runners's Avatar
Member
Member
24runners's Avatar
Quote:
must not be making the connection...cuz that's the correct pin just ground it
you did put the relay back in didnt you?
I didnt wrap the wire around the pin...i just put the wire in the 'hole' of that pin, then put the relay back in
__________________
Old 02-14-2005, 11:55 AM #14
Junior Member
Junior Member
Oh i need to put it in the whole instead of around the pin. Thanks, I'll try it this afternoon.
Old 02-15-2005, 11:00 PM #15
BULECZKA BULECZKA is offline
Junior Member
BULECZKA is an unknown quantity at this point
Junior Member
FOG LIGHT
Hitman, I am interested in doing the mod on thr fogs so they work with my parking lights.....did you do your and did it work, can you send some information
BULECZKA is offline   Reply With QuoteReply With Quote
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
fog light aiming and new fog/driving lights digphisher Engines / Suspension / Wheels / Tires / Audio / Accessories 54 01-15-2023 03:35 PM
fog lights PioneerMeta4 3rd gen T4Rs 14 05-30-2008 11:15 PM
OEM Fog Lights in Facia Speedy 3rd gen T4Rs 12 10-11-2006 05:26 PM
Fog lights install without a lot of info. Iman74 Engines / Suspension / Wheels / Tires / Audio / Accessories 9 08-04-2006 08:17 AM
2003 4Runner fog lights question? testrider 4th Gen T4Rs 3 03-28-2003 04:15 PM
Powered by vBadvanced CMPS v3.2.2
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Copyright © 2020
