2005 Factory Nav w/XM integrated.
Tom Mason
I was able to add XM to my 2005 Limited factory Nav with single in dash CD with relative ease and control it completely from my steering wheel controls. I can access it either from the steering wheel mode control or by pressing the AM button on the HU again giving me SAT1, SAT2, and SAT3. This application doen
XM/NAV
Good Job man...It pays to shop around.
I paid $499 for the one from Toyota.
$100 says it's the same unit...Damn
Does it display more than 10 characters of the song title or artist? My Camry NAV/XM only displays 10 characters for both.
That is the only donwside I have found with it. It only shows the first ten characters of the song and the same with the artist.
Do you happen to know which Toyota XM unit they shipped( i.e. Prius, camary, Landcruiser, etc.)? Have you noticed any problems not having that R11 ground plug? I'm considering this install on my '05 Limited with Nav as well.
Wayne
NoSpeedLmt said:
Can they integrate XM into the 10 speaker JBL unit? Or would I need the NAV?
Let me know if you get an answer to this question, as I am wondering the same thing myself... (or --- if you can use it to integrate the Ipod into the 6dsk changer / JBL 10 spk without losing the changer...)
Anyone have a picture of the rear of the Nav unit which labels what each of the connectors are for? I've seen the one on oemvalue.com website but they leave off the labels on all of the connectors so that you will have to pay them $50.
Well I just finished installing the Toyota XM kit for a Solara in my 2005 Toyota 4Runner Limited with Factory Navigation. Just as Tom has posted, the XM works like a charm. Even though the AM button doesn't say AM-SAT like on other Toyota Factory Nav models it still works the same. Just press AM once for AM and Again for SAT1, SAT2 and SAT3. Each SAT channel has 6 presets for a total of 18 presets.
If anyone is interested I got my kit for $240 from Eddie at Metro Toyota :
http://www.metrotpn.com/ProductDetails.aspx?ProductID=96
Eddie was very helpful and seems more than willing to answer questions.
I found a site that has execellent instructions on how to take apart the dash and rear panel for the Installation here:
http://www.castulucci.com/projects/carpc/oemnaviecuaccess/
http://www.castulucci.com/projects/carpc/oemnaviaccess/
The XM wiring harnes plugs into your CD changer port on the rear of the Head Unit. So you can't have XM and a CD changer or Rear Seat Audio without a Y adapter.
I hope this helps anyone who is also considering this install.:D
This sounds very cool but I am a little confused. When I wanted to install the Toyota 6 disc console changer as an accessory, the dealer told me that there is no available port in the back of the navigation unit for the device. I looked at Coastaletech's website and they said that you could get an adapter that allows three devices to use the AUX port. Does anybody know if the port that the rear seat audio is plugged into is the correct port for this XM kit? I haven't looked behind the navigation unit of a 2005 yet.
Irpete, where did you put the XM antenna? how did you route the wire(s)? how is reception?
Thanks for your post...i think i am gonna do this!
I installed my XM unit in the right rear panel. There's a place under the bracket where it wedges in perfectly without the need for drilling holes. I routed the antenna around the subwoofer and through the right rear taillight. Then i just ran it up and along the outside of the weather stripping ( I figured the I didn't want to mess with the weather stripping and risk leaks). The antenna is mounted in the center rear of the roof.
The signal is execllent. No issues so far with regards to signal. I did loose my Rear Seat Audio as it plugs into the same R14 plug. I'm currently looking into a Y adapter. Toyota makes one for the CD changer, but the problem with that one is that the plug that connects to the cd changer is the larger molex type plug. I will need to find an adapter with three mini molex plugs.
Hope this helps!
Irpete...thanks....but did you mean the right rear panel (passenger side, not driver side, correct?) Thx Again... 4Ride
irpete, besides having to disconnect the Rear Seat Audio connector from the back of the head unit, any other wiring oddities using the Solara XM kit? or was it just plug and play after that. any chance you have a pic to post of your antenna mount? it's ok if U don't. Thanks!
