Jaos Center Protector R Install
BenSD
As requested, here's a brief writeup about the Jaos Center Protector R. I'll share my experiences with this mod.
First off, I ordered it from Jason Burtman, and received it super fast --- nearly next day. I must be really close to the warehouse it was shipped from. Thanks Jason!
The protector came packaged in box that wasn't too big. Here's a shot of it next to the runner to see the scale. The UPS label said it was 31 lbs.
Here is a photo of all the parts unpacked from the box. As another user pointed out, all the items are wrapped in japanese newspapers. It was really fun going through the newspapers.
Next is a photo of the parts after they have been unwrapped from their packaging. The kit is comprised of 4 mounting brackets, the two vertical posts, a crossbeam with the Jaos logo lasercut into it, as well as all the necessary mounting hardware.
All the instructions were in Japanese, but it's a piece of cake to put on thanks to the diagrams. The most difficult part of the install was removing some plastic plugs. They hold the rubber guards in place that protect the headlights from any debris entering the air intake. One of the plugs on each side is located below the plastic bumper, so access is a bit limiting. Other that, it was a piece of cake. Here is a photo of the mounting brackets in place.
After the brackets were in place, I assembled the center protector. It is held together by 4 bolts, two on each side. This unit weighs close to 30lbs, so it's not all that heavy.
When mounting the center protector, I put a towel over the front bumper in order to protect the paint. It was pretty easy to mount with just one person. Just take your time so you don't drop it and gash your front bumper.
Below is a photo of the protecter installed. Sorry for the low quality photo. My camera doesn't have a flash, and ISO 3200 was barely enough to shoot in the low light at f/2.8.
I had mixed feelings about the front protector after seeing it on the 4Runner last night. It looked pretty good, but I just wasn't blown away. This morning when I looked at it in daylight, I liked it a lot more. I think it just took a little while to get use to it. When I mount lights on it, I think it'll look even better.
Overall, the product is pretty well made given how light it is. I like how the top braces go between the grille and bumper. It gives enough room to add the front end mask, which I like to use because it has already saved my paint a few times. However, I do wish that there was a better way to hide the bolts that hold the protector to the brackets. It would be better if the steel from the protector extended behind the bumper where it was then mounted to the bracket. All 6 bolts that hold the protector to the brackets are exposed. If someone had the time and the tools, then could easially steal it. That's not a big concern in my area, but you never know. I'm going to see if there is some way I can drill another set of holes through the lower brackets and add a lock, or something to stop the wannabe theives.
The build quality is pretty good, but this is not something you're going to use to push other vehicles. The brackets simply aren't built for it. It would be nice if they beefed up at least the lower brackets, but it looks like the existing holes were tough to work with. This is mostly for holding lights, and protecting against the idiots out there who use impact with another vehicle as an indicator that they are too close when parking their car. That is one of the reasons why I decided to get this protector. Someone ran into the front of my runner just a few days ago in a parking lot. Some blue paint rubbed off on the front, and it did some other very minor scrapes to the paint. I think I'll be the only one that notices the damage, but it was frustrating nonetheless.
This morning, I decided to see if I could put on the front end mask with the Jaos Center Protector R in place. It took a little bit of convincing to get the mask between the bumper and the protector, but if you sneak it through the gap that's formed by the lower air intake, it works fine. None of the clips on the mask interfere with the protector. I'm anxious to see what the protector will look like with lights. Needless to say, I think my front end is pretty well protected now...... between rocks and soccer moms, I'm in pretty good shape.
BenSD - Thanks for taking the time to take pictures and doing a write up. Also, I really like that first picture you posted of it on your truck as it looks very "artistic"
Part of the reason that turned me off on the center protector were the exposed bolts you mentioned. The ones that bugged me the most were the ones that go to the mount in the center grill. Since its pretty high up, its noticeable unlike the ones that are closer to the ground. Can you take some pics of the mounting points? Also, how thick is the center protector parts? I noticed that it flares out in the front (chrome) and then narrows down. Whats the thickness of the narrower part.
Are there mounts for lights built into the center protector or do you have to drill into it?
Oh yeah, lets be honest another reason I didn't buy it was price. Kudos for you though because it still looks AWESOME!
BenSD said:
Now that I have the protector installed, I'm in serious need of some added lights.
Looks great !!!! and YES, You need some lights... I think it was ment to be that way. Without lights it looks like it's missing something.
Good write up and I'm sure it will help others...
Looking good!!! Looks really neat with the cover/bra.
All Jaos prices are going up 8% for every dealer. I still sell less than anyone else, but I'm going to have to raise the prices very SOON! The Jaos cp is on sale at $599 not much longer!
BenSD--
How do you like how the protector looks from the side in person? From the photos I'm not sure I'm too crazy about it. The reason I ask is because mine should be arriving on Tuesday. Trying decide if I still want to install it, or possibly return it. Though I'm not sure what the return policy is. I have looked at this center protector for months and have never seen it shown from the angle of your photos. They probably haven't wanted to show the bolts that are very evident to me. I still think it looks very cool from the front though.
PedsFlightRN said:
BenSD--
I wasn't a huge fan of the exposed bolts on the side, but once I installed it, I think it looks fine from the side. It's probably not what most people will expect after seeing the highly polished leading edge, but I think it's good the way it is. The side pannels are not pollished, so they don't look too "blingy." I think it would be going overboard if they were polished as well. It's pretty much the same type of design as the brush guards out there. My lights will arrive sometime this week, so I'll post some pics with the lights.
Very sweet!! :D I had been debating whether or not to go with the Jaos lights, but I think I have my decision. My center protector arrived late this evening--I know what I'll be doing tomorrow!
The Jaos lights are super easy to install. I didn't have a deep enough socket wrench to get to the bolts so I made due with a makeshift setup. It worked just fine to tighten the bolts, but I did manage to slip and bang the bumper. It left just a small mark..... should blend in with the other rock chips....
I found a cool place for the remote control. I put it in the overhead sunglasses holder. Just press the button and the compartment opens, exposing the remote control.
Okay, so I put mine on today. Had no problems, but did put the brackets on in the opposite order of what they had suggested. Made more sense to me to do the the bottom most ones before the top ones. So, anyhow, here is how it looks on Galactic Gray. Now I've GOT to order those lights!!:D
Sorry about the mess around the house. We just built a new garage and are also in the process of having the house repainted. Lots of projects going on here. I'll have to take better pics once I have the lights and when the rig is clean.
So, now after looking at the pics myself I thought the protector looked off-center to me. So I went back outside and measured. It is off-center by about 1/8 to 1/4 of an inch. I'll be trying to fix that tomorrow.
Looks great on the gray! It really brings out the silver bumper accent. Your truck is the exact one I originally wanted, but after it was totaled at the port, I went with the white.
PedsFlightRN - Your third pic looks really good. The squared off lines of the JAOS really complements the 4runners look. I'm happy with my T&H, but would be happier with the JAOS.
BenSD - I think, with your bra, your ride would look much better with the 2005 SR5 chrome grill. It only costs a little over $100.
Peds, I have a someone asking me what size tires you added when you did the cornfed lift? Can you tell me?
