View Single Post
Old 04-16-2012, 04:36 PM
crackiswack's Avatar
crackiswack crackiswack is offline
crackiswack is on a distinguished road
Originally Posted by BReardon21 View Post
you got FJ springs? if not, what type of lift you got? any pics?
just trying to gauge what it will look like final numbers I figured the rear is currently 2" higher from the front. So with the FJ rear coils I should get another 0.75-1.00" lift therefore I need at least 2-3 inches out of the front it should look level. I am thinking with 2010 FJ coils, v8, 4WD, Push Bar, and Rola Rack then the 0.85 will actually be about 2" of lift so now the rear will be a good 1" over which will still allow the truck to maintain a stockish stance. The last thing I want is Bro lift, so rather keep her ass up than her nose in case I load the back or tow anything. Thanks Crack!
I don't have it yet but I've done enough research, and read up on the suspension geometry. First, the FJ rears will not give you 0.75-1", most people get around 0.5". The 0.85 setting gives you around 1.5" on the stock springs, closer to 2" with FJs. the 1.75 gives you around 2.5-3" with the FJs. Some might consider that level but if you want to keep some rake you need to run 0.85" setting. A 1/4" spacer on the front may get you closer to where you want to be.
crackiswack is offline   Reply With QuoteReply With Quote
