Just curious, why are you using a spacer in front since you just installed the 5100's which are adjustable? Your sig also says you have a DS 1.5" rear spacer. If I were you, I'd ditch the front spacer and set the 5100's at 1.75".
Also, it sounds to me that you didn't take the entire assembly out to change out the shock. Did you loosen the 3 top bolts on the top plate and slide the coil over assembly out? That's how I did mine, pretty easy job (I've done it twice now) so I'm not sure how to answer your questions.
"I'm addicted to speed but not the drug..." - Swollen
2005 SR5 V8 | OEM LED tail lights | Wheelskin leather steering wheel cover | Scion T1808 HU w/ iPod adapter | 35% tint (match rear) | FJC coils w/ Bilstein 5100's (2.25 setting) | Toytec Superflex rear coils | WeatherTech digital-fit mats | Mini Morimoto HID projector retro-fit | Spidertrax | AFE drop in | GY Duratrac's (285/70-17) | headlight blackout DIY |
