Originally Posted by ARK_SWAMP_RIDER
Yes, you will remove the spacers in the rear and lower the setting on the front shocks to the lowest setting.I haven't seen exact numbers on the fj coils, I'm guessing 3%-5%. A body lift up to 1" will only require a radiator relocate, up to 1.5" you'd need a steering spacer.
Do you have a v6 or v8?
ASR, I went with the OME 885's and the TT Superflex's for the rear. Thanks for your help brother! Could you please refresh me on the spring install...So I will set the 5100's in the front to the lowest setting and just install the superflex's with no spacer in the rear. This should even out the rake and put me at a 3" lift?
