Thread: Brake Booster??
View Single Post
Old 06-13-2012, 11:53 PM
SV_Dude SV_Dude is offline
Moderator
Real Name: Jonathan
SV_Dude will become famous soon enough
Moderator
Real Name: Jonathan
The brake booster is nothing more than a vacuum actuated braking assist. When you push on the brake pedal the brake booster opens a diaphragm and allows vacuum pressure from the engine to push on a rod in the master cylinder vie the front half of the brake booster.
That whoosh you're hearing is a vacuum leak in your brake booster. Your booster is definitely bad. Another sure way to tell if you have a vacuum leak in your brake booster is with the engine running and you step on the brake, the RPM's will drop a little bit because of the vacuum leak. Once you replace your brake booster and you're careful not to damage your master cylinder you should be fine with no further worries.
SV_Dude is offline   Reply With QuoteReply With Quote
