Originally Posted by ATL4R
Not happening. Adding KDSS would require a new frame, new control arms, new sway bars, new hydrolic lines all the way around the vehicle, electronic KDSS sensors, KDSS ECM/computer module, etc... you get the picture
Just get ADDCO swaybars with a quick disconnect if you are not comfortable with the on-road handling of the 4Runner. Off road, your non-KDSS vehicle should perform just as well (or better if you remove your swaybars) than one with KDSS.
It's hard to add options from one trim-line to another. Toyota left out any additional wiring harnesses you didn't pay for.
Dad has a 2011 Limited and I have a 2012 Trail...there are only a few options that I'd like to add. Agreed that the Trail is the best starting point.
