Originally Posted by BlackCat914
as far as I know, the actual diameter of the link is the same, it's just the length that's different. I'm thinking I'll be good as long as replace BOTH of the rears so the length matches. I'll definitely keep you posted if they don't work though!
From what I remember the front endlinks are actually thicker than the back. I couldn't reuse the washers from the front on the back because of this.
Originally Posted by hrt4me
do the longer end links help when you install a 3" lift?
Yeah they make the rear swaybar a bit more parallel and allow for more articulation.
