Originally Posted by jconusn
I just measured the actual spacer, (I have the 2.5/1.5 kit but I am only going to use the rear 1.5 after much deliberation). It is 1.5" thick for the front but it nets more than that for some complicated reason... Explained here, by Ark Swamp Rider, who is the man when it comes to these matters by the way:
"With the 4runner front suspension (this ONLY applies to the front), you gain approximately double the spacer thickness. A 1" spacer yields 2" of lift. As spacer size increases, the ratio goes down slightly. You'd still be looking at about a 1.25" thick spacer, or possibly 1.5" thick. I can't say exactly how much because I've not installed anything over a 1/2" thick spacer.
The rear is simply the spacer thickness. A 1" spacer gives 1" lift."
On a side note, thanks to Ark for all his hard work getting all the FJ/Bilstein etc. info together, it helped me out a LOT.
Thanks for the info! If that front spacer is actually 1.5" thick, then folks should be getting 3" of lift. I really don't want more than 2.5" of front lift with 1.5" in the rear. I guess I will keep searching the forum to see if anyone else has reported actual lift heights...
