Originally Posted by brandoc0mmand0
Dude your rig is beautiful! You have just about the same setup I am looking to run. 275/65/18 BFG TA KO, Daystar 2.5/1.5 and Spidertrax 1.25"
Did you encounter any rubbing on the body? I know a front mudflap removal, fender liner moving, and some bumper trimming is necessary though. Id like to do everything at once then get the truck aligned to get the max life out of the tires.
When you first did the lift + tires, were you running the stock XREAS suspension?
You'll get some rubbing with the 275/65/18 and Daystar kit with xreas. Nothing that can't be solved with some trimming. Less trimming is required when running this tire size and the Radflo 2.0 kit since I'm getting about 1/2 inch more lift.
