I'm sure it's a dealer (special order likely) item since it's spot welded in. The big question is what's wrong with it? Why are you replacing it?
I cut the center section out of mine to fit a, um, box, under the seat. It probably provides some structural support but it's probably not necessary to hold the car together (provided you still have enough to hold the seat down).
2002 T4R Limited, 191K miles - OME 883 front - LC 7 wrap/2nd gen sway bar links rear - Detroit Truetrac Diff - Cooper A/T3s - Warn M8000 - ARB Bumper - homemade (er, 'custom') rear bumper w/tire & can carrier - BajaRack - Diff Breather Mod - Hayden trans cooler - Yaesu 2M, Cobra CB - Fridge, off-road trailer with Tepui RTT (real expo poser)In Africa they say: "Buy a Land Rover and it will take you anywhere. Buy a Toyota and it will take you there ... and bring you back home." jannikt on wranglerforum.com - I'm guessing he didn't make many friends there with that line.
