Originally Posted by SSt4r
On your HID kit, I have the same and was having problems: 1st one side then a year or so later, the other. I finally found bad fuses. They didn't look blown but had failed (either overheated or corroded - they had swelled at the base). Replaced the fuses and both now work fine!
Okay I will check those and see if that is my problem. I am hoping that is it!
