Originally Posted by KVA
The only switches that fit the stock locations (even these need a little trimming on the internal switch side) are these made for the Prado 150 (Toyota Type 1 Switches)
The OTTATTW switches (Contura V or X, etc...) all require trimming to the actual hole size to fit - though they do "pop in" when the hole is the right size. Otherwise you should consider what others have done and buy the three or six switch holder and carve up a good rectangle position on the lower drivers side to fit one of these...this will provide more options.
See
@ jangoforhire
's build thread for switch inspiration!
Thank you for that clarification.
