[QUOTE]Originally posted by AlexJet
[B]Sometimes, in the mud, to get out you need spin all 4 tires and A-TRAC start blocking power, so you stucked. I was stucked couple times exactly by this feature. My friends Rubicon with front+center+rear lockers moved out due to spinning all 4tires (we both run GoodYear MT/R and his Rubicon is not lifted). Another time I was surprized how easy (compare to my stock central lock and ATRAC) another 4th Gen with ARB front+rear locker passed by place I was stucked for 1/2 hour.
I'm not saying A-TRAC is bad. It's just all depends on conditions. As someone already mentioned, there some cases where A-TRAC will work better then lockers and there are some situations when lockers will keep you moving and A-TRAC wouldn
