Originally Posted by BlackWorksInc
*snip
* Thus no matter what you do, you still need to foot the bill to have the transfercase removed, torn-down, and then rebuilt (in the case of adding this manual linkage system, you'll need to find a shop that is willing to do the work; some may not due to liability reasons) so you're looking at an expensive modification/repair either way. You might just be better off getting an aftermarket transfercase or even trying to adapt an FJ cruiser manual transfercase (which may be easier to be honest.)
I would have to have a tcase in front of me, but just off the pics ive seen, I think an external shift linkage could be setup using the existing shift rails.
altho, a set of dedicated rails would likely work better.
luckily, my actuator was replaced when I bought it. I think it if ever fails, i'll attempt to fabricate some sort of mechanical linkage system.
I would still exercise it in both 4Lo and CDL ON once a month, the idea is to get the actuator to move so it doesn't seize up which is what typically happens.
im pretty that before me, mine had never been shifted into low range. due to this, it was stuck. I wasn't surprised really. im just glad that because of this site I knew to check it on the test drive.
1985 pickup
: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5
: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited
: stock.
Build Thread YouTube Channel
