Join us now!
Remember Me?
FAQ
Social Groups
Calendar
Photo Albums
FAQ
Social Groups
Calendar
Mark Forums Read
Toyota 4Runner Forum - Largest 4Runner Forum
Forums
Thread
Toytec 1" Body Lift
View Single Post
05-03-2014, 12:40 AM
nor_cal51501
Real Name: Shane
Member's Picture Albums
nor_cal51501
Real Name: Shane
For the time being you need to leave the rag joint disconnected so there is no stress on it while jacking the body up off the frame.
**IMPORTANT: DO NOT ROTATE OR MOVE YOUR WHEEL ONCE YOU DISCONNECT THE RAG JOINT OR IT WILL BE DIFFICULT TO REPOSITION AND CONNECT!**
Step 4 - Installing spacers and new body bolts
This step is where I didn't really take as many pictures because the sun was going down, the instructions SUCKED, and I wanted to finish. I started with the drivers side front and worked my way to the back. All the body mount bolts are 17mm inside the car and 14mm outside the car with the exception being the front mount bolts. They are 14mm on the top and bottom.
Only take one side of the vehicle apart at a time! Make sure to remove all the body bolts for one side before attempting to jack the body up.
Make sure to not mix up the bolts and their locations or their assembly order.
I took one body mount off at a time and reassembled it off the car. Until I was ready to reinstall that particular one I left it directly beneath the mount location it belongs with. Once the 5 body mounts for the drivers side are removed, switch out the hardware to the new bolts of correct length.
-The front body mounts use the longest bolts supplied.
-The drivers and passenger kick panel bolts get replaced with the shortest bolts supplied.
-The body bolts behind the drivers/passenger seat and underneath the rear seat both get replaced with the middle length bolts supplied.
-The rear body mounts in the cargo area get replaced with the shortest bolts supplied.
I used a 27mm socket and a sand filled rubber mallet to remove the built on washers from the original bolts. I put the socket over the head of the bolt and gave it a few good smacks and the washer came right off each bolt.
Washer removal
After switching out the washers and hardware jack up the body in the middle of the side of the vehicle so it goes up evenly front to rear about an inch or slightly more to allow the pucks to be inserted in between the body mounts and the body. One at a time insert a puck and reassemble its body bolt and hand tighten them.
Important: There are two spacer pucks that are smaller in diameter, they are the front body mounts and shouldn't be confused and used elsewhere.
After all 5 of the drivers side mounts have been switched and hand tightened lower the body back down.
Drivers side done
Repeat the same exact procedure for the passenger side.
-The new body bolts and nuts are 14mm for both the bolt and the nylon lock nut.
Once both sides are completed you can go around the vehicle and snug up all the nuts and bolts for the body mounts. Then reinstall the interior panels in reverse order.
Driver front body mount - Top
Bottom
Drivers kick panel mount
Mount behind drivers seat
Mount next to rear passenger seat - drivers side
Rear drivers side mount
Rear passenger mount
Mount next to rear passenger seat - passenger side
Mount behind passenger seat
Passenger kick panel mount
Both front mounts
Step 5A - Reinstall the bumper
Bumper installs in reverse order, but make sure to align the fender bolts on the bumper to go into the fender mounts. They need to be angled up a bit in order to make it to the raised body.
The body is now 1" higher than the front bumper, so the bumper will be angled slightly downward now.
The bumper bolts to the frame should be torqued with a torque wrench to 32ft-lbs. The fender bolts can be hand tightened to snug fit.
If you want to avoid the nose dive and gapped bumper skip to step 5B
Gapped bumper with downward angle
'01 Sport:
E-locked
, 285/70/17's,
T
U
R
D S/C,
200k club
My Build:
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
12:35 AM
nor_cal51501
View Public Profile
Find More Posts by nor_cal51501
nor_cal51501
View Public Profile
Popular Tags
3rd
4runner
4th
5th
air
area
axle
back
battery
black
brake
bumper
car
door
engine
fluid
front
fuel
gen
good
head
issue
i’m
key
kit
led
lift
light
lights
limited
miles
noise
oem
oil
part
parts
power
pro
pump
rack
rear
replace
replaced
replacement
roof
running
sensor
set
shocks
side
sr5
start
steering
stock
switch
system
time
tire
tires
toyota
transmission
trd
truck
turn
unit
vehicle
wheel
wheels
work
wtb
» Follow Us!!!
» Log in
User Name:
Password:
Remember Me?
Not a member yet?
Register Now!
» T4R Sponsors
Become a Sponsor
Powered by
vBadvanced
CMPS v3.2.2
05:44 AM
Search Engine Optimisation provided by
DragonByte SEO (Pro)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
Advanced User Tagging (Lite)
***This site is an unofficial Toyota site, and is not officially endorsed, supported, authorized by or affiliated with Toyota. All company, product, or service names references in this web site are used for identification purposes only and may be trademarks of their respective owners. The Toyota name, marks, designs and logos, as well as Toyota model names, are registered trademarks of Toyota Motor Corporation***Ad Management plugin by
RedTyger
Toyota - 4Runner . org Forum
