Just saw the thread, here are my issues:
2004 V6
HG leak at @125,000
Same problems as other posters, rough start and misfire on cylinder 6. Coolant also fouled oxygen sensor. Total bill was around $1900 to replace the gasket, check the heads and replace the o2 sensor.
Other issues:
Leaking crank shaft seal due to improperly machined harmonic dampner. Took forever to trace and find the source of the leak. While replacing the seal I also found that the radiator was leaking. This was around 130000.
No other issues since.
