When rubber slats on the quarter vent louver are gone, water sprayed horizontally (such as from car wash) could get inside the body panels and cause damage such as shorting/corroding the rear window/wiper control relay module.
Could have used mountain bike inner tube but did nothave any handy so, I used rubber sheet from Marshall's Industrial Hardware that's approximately 1/32-inch thick to make the slats...
Here I marked where to slit/poke holes for mounting...
Assembled:
Assembly detail:
I used soldering iron to remove mushroom head on plastic heat stake and re-staked after installing slats.
Here are retainers needed for First-gen MoreFunner...
It is almost impossible to remove vent cover without breaking these retainers so make sure you have some ready before starting the project.
Upper retainers are PN 62955-89101, 4 per side on first-gen MoreFunner
Lowers are PN 62955-91C01, 1 per side on first-gen MoreFunner
Louver re-installed:
