Originally Posted by HiluxSurf SSR-G
If the FJC front coils can be used on the 3rd gen 4Runner, then the front coils from the TRD Pro 5th gen 4Runner can be used. Is that correct? just a thought that it might give a better ride with the same lift as that of the TRD Tundra progressive coils. However, it doesn't seem to be progressive though.
shiny red coils from the TRD Pro 4Runner:
TRD Pro parts
Doesn't look like it. I'm assuming the TRD pro's have the same suspension as the tacoma baja's, which would mean the springs are flat on the bottom. Our setups use a pig tail ended coil. You would have to custom machine a lower spring perch to make them work, but I'm sure it could be done. That's basically what Toytec does to make their coilovers for the Bilstein shocks. I'm willing to bet those TRD springs are made by Eibach. Just a 15 or 16" coil, 3" diameter, 600-650lb spring rate.
