I may be facing the same issue, but sadly when I test my relay with a volt meter, it works. Apply 12V across the silver leads and continuity across the brass leads. Cycled it a few times, and worked every time. Guess I have to chase things down a bit. Don't have many options on my vehicle such as inverter, so can't easily swap around in the relay block to field test. Other thoughts are welcome.
