Your water pump should be changed with the timing belt.
That sticker should have more than just the year it was replaced. It should also tell you how many miles your rig had when it was replaced. There is some debate about how often they should be replaced, but 100k miles is usually what most people say, give or take, so unless you've been driving it a lot I doubt it's time.
Some people let it go longer, because it's a non-interference engine, so you won't have any damage if the belt breaks, but that is up to you.
The Renewal of Gaia 1999 4Runner SR5 Highlander IJM
FJ Wheels | Goodyear Wrangler Fortitude HT | TBU
Rancho Shocks & Struts | OME 880 Front | OME 906 Rear | ES Polyurethane Sway Bar Bushings Front/Rear | ES Polyurethane Steering Rack Bushings
Clear Headlight Corners | '98 Rear License Plate Frame & Emblem Delete | Stubby Antenna | Trans Cooler Bypass
