Originally Posted by wfo9
Ouch, the dreaded KDSS failure. This is why I don't like one off systems like this.
I'm sure you could get some help here with what it would take to remove it and use regular sway bars. It seems like it would just be the LCAs in the front. Then all the links. I would hope the mounts on the rear axle are the same...
I'm sure someone knows.
Many people run with no swaybars at all, but it takes some getting use to and can be a little unsafe in an emergency maneuver. You could at least do that while waiting on parts...
I'm pretty sure you could use KDSS lower arms with a normal sway bar, but you would need new spindles, for sure. Not sure all of the correct holes are on the frame for the sway bar mounts, the frames have different part numbers.
