Then just pop off the trim piece we are replacing. Here is a pic of the old and new trim pieces side by side:
STEP 9:
Clip the new trim piece to the glove box assembly and re-fasten the nine screws you removed in the previous step. Here is the glove box and trim all put together and back in place:
STEP 10:
Re-install all of the pieces you removed, in reverse order. One thing to note as you are reinstalling the air bag - there is a small hook that latches into a slot near the two mounting bolts you removed in step 5. Make sure you re-hook this before reinstalling the bolts. I missed this the first time. You will not be able to screw it down if you miss this. Here is the best pic I have of this:
