Tapping that switched ground in the overhead light is a little bit of a trick, as it is totally internal to the light fixture--no wire, just a short brass strap from switch to bulb. In my case, I have an adapter in place of the bulb to wire in a flat panel LED. Using one of those gives you a wire to tap--might make it easier to tap and the LED in the dome is great.
Good research and planning on your project. I want to see how you get a wire from the dome to the foot.
My Backyard Frame Swap
