Real Name: Jeff
Real Name: Jeff
Search for replacing steering rack bushings. The process is the same. You shouldn't need to take of the pressure lines unless you want to.
If you were already going to replace the lca bushings, could you get lca's from a salvage yard?
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
