Originally Posted by TheDurk
Did you switch to the 200ma port and setting? You should see 25-50ma from the radio and wireless door systems. If not, you are probably not making good contact with your leads. If you do, you have an intermittent drain or possibly an internal short in the battery. How old is the battery?
You can rule out the battery by leaving the negative terminal off for two days and see if you can start the car when you reconnect. Also check voltage at beginning and end of the period just before you reconnect.
I have aftermarket radio, not hooked up and aftermarket wireless door system that worked last time I used it.
