Originally Posted by Krayziekid
Hey dude. So I actually found some free time just now and filmed a short little clip on my camera for you. Hopefully this is what you were looking for. I just uploading to Vid.Me cause it's easy and I don't have a youtube account to put this on, so hopefully this embeds and works lol.
https://vid.me/hajw
It's pretty straight forward. Showed all of the different lighting modes with blinkers and hazards on each one. I underexposed it a bit so everything wouldn't be blown out when the high beams came on. I think it worked pretty well. It starts with the DRLs on, and then I go through the motions. Sorry about the glare when the headlights came on. Just the way the light happened to hit my camera. Let me know if you need anything else.
In case anyone is wondering, I am using TRS LEDs in the high and low beam and they look fantastic. I haven't driven in the dead of night yet, but I drove it the other day when it was fairly dark out. They through a ton of light and it looks great.
Edit: For some reason, the video isn't working as intended. Give me like 10 minutes to figure it out and I'll put a new link up.
Edit2: Now the video is working and correct. Hope this helps.
That looks incredible! Thinking of doing this as well as adding a bulb to the rear bumper reflectors. May bite the bullet and install the retrofit kit from the retrofit source to run hid's and so I can use the projectors for the high and low beam function. Thanks for the awesome write up!
