Originally Posted by 1engineer
Started in August. If you were a member before then you get grandfathered in and can start a thread with less than 15 posts.
Ahhhh ok.
Stock for stock, TRD Pro should be better than the Trail Premium in offroad conditions. If you plan to upgrade the tires and suspension, trail premium with kdss will give a little advantage. It'll be a little more planted on the road and should give a little more articulation offroad from what I've read.
If a sunroof is a must, trail premium it is. If a trd pro exclusive color is a must (quicksand), then trd pro it is.
