Originally Posted by SSt4r
Maitre, You can disconnect the metal line at the other end where it meets a flexible line. Make sure you then remove & re-use that short metal line on your new caliper. When installing, keep the connections loose until the caliper is bolted on, then tighten the lines.
SST4r, would I need to clamp the flexible line before the disconnect in order to prevent any brake fluid leaking?
