Originally Posted by BOFFROAD
Your CB install is probably my favorite one Iv'e seen on here. Its clean!
Thanks! It has taken forever. I still need to finish up the cubby's mount as it isn't sitting flush right now and route the cb cable to the hatch. I barely had room to cram the dremeled cb box behind that panel. Plus the knobs stick out far enough some tall cups in the cupholder don't sit flat. I may have to lower the cupholder's base... If I had to do it over again, I might have just stuck the whole thing in the center console!
Modified/Chopped CB Box:
Installed with my wire extensions:
The process: Cut, try to force fit, cut some more, shove it in there, cut even more, repeat. Trying to get the silver trim panel snapped completely in was the worst.
I should rename my build; "I apparently have too much free time build"
2005 4R Sport 4WD
"The last of the V8s!" - Custom TIG'd SS Dual Exhaust - King 2.5" +2 LT. - ARB Front & Rear - 37's - Dana 60 -
Build Thread
1977 Celica Liftback - LFX Swap -
Build Thread
