Originally Posted by JD914
I don't know if this answer is too simple, but in order to fix the flashing/load problem without having different looking flashers in front, what if you kept regular bulbs in all 4 front turn signals, and put led's in the REAR? That way, you don't overload everything, and the different flash is only seen from the rear (or side, I guess)?
That might work, but honestly I'm fine just running the normal bulbs for now. They get the job done.
I'm not sure if the relay is 4 channels @ 27w each though. If that is the case, then that means changing the back won't affect the front at all.
