View Single Post
Old 03-27-2016, 07:52 PM
NoVAphotog NoVAphotog is offline
NoVAphotog is on a distinguished road
Daniel's 2000 5-speed 4x4 SR5 Rescue, Restoration and Maintenance Thread
2000
Toyota 4Runner SR5
Black/Oak
V6
4x4
5-speed Manual
Rear E-locker
This thread will serve as both a maintenance log as well as a place for pics of of adventures and enjoying her.
Maintenance Log:
Date - Miles - Action and Parts
03/06/2016 - 151,160 - R&R Battery, Engine Air Filter, low beam headlight bulbs - Autocraft Gold (Advance Auto), Percolator Filter, Sylvania bulbs
03/22/2016 - 151,324 - Mount and Balance Four New Tires, 265/70/16 Toyo Open Country A/T II, replaced negative battery terminal
03/24/2016 - 151,332 - R&R Front Swaybar Endlinks (OEM), rear shocks (Toyota), exhaust cat (aftermarket), pipe and muffler (aftermarket), fuel filter (Toyota), F (Bosch ICON, 17in) & R (Toyota) wiper blades, license plate bulb. Adjusted emergency brake, drain & refill engine oil (dino), r&r engine oil filter (Toyota). Surface rust removal and sealing, Safety Inspection Completed.
03/26/2016 - 151,370 - Drain and Refill Rear Differential Fluid with 2.8qts Mobil 1 75W-90
04/02/2016 - 151,400 - Drain and Refill: Transfer Case (Mobil 1 75W-90), 5-speed Manual Transmission (Redline MT90), Front Differential (Mobil 1 75W-90)
05/12/2016 - 151,800 - Programmed new key fob/door remote. Purchased new Toyota key as well.
05/15/2016 - 151,850 - Removed and replaced TB intake boot, hose clamps, and PCV Valve and grommet. Cleaned MAF sensor with CRC MAF cleaner. Cleaned throttle body with CRC Throttle Body cleaner. Adjusted throttle cable to reduce pedal slack. Greased clutch assembly. Cleaned VC and tightened bolts.
06/03/2016 - 151,871 - Timing belt and water pump remove/replace, new tensioner and pulley along with Gates belts. Genuine Toyota Spark plugs installed along with NGK wires. Toyota Red coolant flushed. Genuine Toyota Brake Fluid flushed as well.
06/05/2016 - 151,910 - Upstream Air Fuel Ratio Sensor replaced (Denso 243-9003). Check Engine light cleared. 50+ miles driven, no more codes! Engine runs smooth as butter.
06/07/2016 - 151,975 - 35% Suntek Carbon window tint installed on front driver and passenger windows.
06/27/2016 - 152,350 - Washed, clayed, Meguiar's M105 Compound applied to hood/roof, Meguiar's M205 polish applied to main panels, paint sealed with Menzerna Power Lock polymer sealant.
06/28/2016 - 152,376 - Interior upholstery cleaned using RugDoctor 5000 and hand tool/ Rug Doctor upholstery cleaner.
07/16/2016 - 152,840 - Power Steering Fluid changed w/ Redline D4 ATF
07/25/2016 - 153,175 - Oil and filter service (Mobil 1 5W-30, Toyota filter), Driveshaft and U-joints greased.
09/26/2016 - 154,823 - New Toyota Lower Ball Joints and Outer Tie Rods installed. Front End Alignment performed.
12/13/2016 - 157,364 - New Toyota Front Rotors and Pads Replaced, brake fluid flushed. Clutch fluid flushed with Genuine Toyota fluid. Cleaned and lubricated rear shoes and adjusted e-brake.
12/17/2016 - 157,570 - Undercarriage power washed and cleaned. Fluid Film applied.
12/24/2016 - 157,700 - Oil and filter Service (Mobil 1 5W-30, Toyota filter)
1/20/2016 - 159,200 - Pioneer Single-DIN Bluetooth Headunit Installed.
3/26/2017 - 161,850 - Genuine Toyota 99 Limited Black Rear bumper assembly installed. Removed stock chrome bumper and discarded. Flipped hitch upside down as well.
6/5/2017 - 162,880 - Genuine Toyota Rear E-locker Housing and 4.10 locking differential installed. Factory e-locker ECU and RR DIFF LOCK switch installed and wired for factory operation. Grey wire mod completed for locker use in 2Hi, 4Hi, 4Lo. Valvoline 80W-90 fluid used (will flush in 2k mi). Brakes bled after install.
6/11/2017 - 163,500 - Rockford Fosgate P300-12 powered subwoofer installed. Stuck closed sunroof assembly removed and replaced with new to me 72k mile assembly, cleaned and greased before install.
6/23/2017 - 163,740 - Mobil 1 5W-30 Oil and Toyota filter change. Upper tail light bulb replaced.
9/14/2017 - 166,400 - Bilstein 5100's + OME 906 springs installed in rear, 5100 + TRD Off Road Tundra Coils installed in front. ARB front bumper installed as well.
9/15/2017 - 166,480 - 4 Wheel (front) Alignment performed.
12/01/2017 - 168,918 - Tires rotated. Mobil 1 5W-30 Oil and Toyota filter change.
12/15/2017 - 170,686 - Clutch fluid flushed.
1/12/2018 - 173,737 - Tires rotated. Mobil 1 5W-30 Oil and Toyota filter change. Vehicle washed/detailed.
2000 Toyota 4Runner SR5 4x4 V6 5MT w/ E-locker - Restoration/Maintenance Thread
1996 Toyota Land Cruiser x3 locked - Restoration/Maintenance/Build Thread
NoVAphotog is offline   Reply With QuoteReply With Quote
