This guy is 6'8"..I thought about doing the washer thing since I'm 6'1" too
Easy:
Originally Posted by LTDSC
Finally got a chance to look at my seat. I ended up solving my issue very easily. I took the front two seat bolts out, loosened the rears and found 6 washers. 3 on each side and then tightened everything down. This moved my seat a noticeable difference upward on my thighs and leaned it back some more. This also still left me with good amount of threads to still anchor the seat into the floor. I was even able to move the back of the seat forward once this was done. All in all, its minor but so far it seems to fix my height issue. I went from looking out the top of the windshield to looking more out the center, which is a big help on my neck.
If you didnt know any different you cant even tell.
Advanced:
FINALLY got time to hit the shop and lower my seat. What a difference! I feel like im so much lower. I see out of the middle of the windshield, not the roof, i no longer hit my head/hair, can close the sunroof and NOT hit it. Im so happy i was able to do this and i took plenty of pics for everyone.
Seat removed
Friend grinding the edges of the brackets
You can see our cuts on the lower bend here
Hit it with a hammer to flatten it out, can also see our second cuts on the outer most bend on the closer bracket. Farther bracket is flattened as well.
Test fit to make sure thats enough
left is original, right is the one we cut and bent (huge difference)
Little welding to sturdy the brackets and make it right, also welded the top cuts after picture.
Bore out the mount holes a little and tape up the side panel to trim. Used washers on the seat bolts to cover the bigger bore.
I taped and then cut the side panel with the dremel and a disk.
Closer look at the bracket now
Installed, you can see where i cut a little too much off. I also sanded down the burs/edges from the dremel cut. The picture makes the edge looks a lot more noticeable.
08' 4Runner SR5 4WD V6 Level 8 MK6 wheels//Kenwood DDX9903s//JL 10W3v3 on 500/1//LEDs//ICON Ext Coilovers FR//Metaltech LT Rear Springs w/ Dobinson LT Shocks//JBA UCAs//spidertrax//5th gen brakes in front//295/70/17 Cooper Maxx//SS brake lines//
http://www.toyota-4runner.org/4th-ge...ld-thread.html
