View Single Post
Old 05-05-2007, 08:48 PM
TechWrench's Avatar
TechWrench TechWrench is offline
TechWrench will become famous soon enough
TechWrench's Avatar
Originally posted by a77boy
Mechanical relay as far as I know. I managed to take apart the relay next to it, EFI i think. It is a little different, but It is definetly mechanical. The magnetic clutch relay should be the same. As stated before, I simply banged it on my counter top and it has been working for two months. :-)
I remember that from your earlier post, so I suspected it was a mechanical relay, but wasn't sure. Banging a solid state relay shouldn't 'help' it at all. I'll have to look at the contacts when I operate on mine. I suspect they will either have arc deposits which are increasing the resistance across them to the point that they won't activate the mag clutch, or they are welded shut and won't open.
I can Explain it to you, I can't Understand it for you.
'08 Tundra SR5 5.7 V8 Double Cab, White, Equalizer WD system, '91 Coachmen Catalina 260FK, '89 Grumman GSS w/35HP Force O/B, 8' Snowbear utility trailer, 2012 Polaris 500HO LE in Camo, 7 x 14 TWF Landscape trailer w/2 ramps.
TechWrench is offline   Reply With QuoteReply With Quote
