Originally Posted by shahsmerdis
Um,
you need more details man. if its just a simple radiator, why get rid of it. What could those few things be? Do you have an scan gauge? what temperatures does it get too? what color does the coolant look like? is it dirty? when was the last time you did radiator, water pump or tstat?
how does the fluid look in the car? do you have any shifting or engine problems, rough idle before the car over heats?
Great questions!
No unfortunately, I don't have a scan gauge.
The coolant does not have a color it's evaporating and creating steam out the exhaust pipe hence the white smoke. So if I drive the truck it leaves a heavy trail of white smoke.
A water pump timing belt was done at 204K miles. Radiator was at 189K
Yes it was idling rough before the white smoke started but no shifting problems.
A local mechanic said it could be a head gasket but didn't want to take on the project.
