View Single Post
Old 07-09-2016, 04:33 PM
jingksed jingksed is offline
jingksed is on a distinguished road
Thanks!
Originally Posted by cutty01 View Post
In addition to the lift,
1. The guide recommends installing aftermarket LCA/UCAs for 285s (33s) so you have more flexibility to get you to stay within factory alignment specs and possibility eliminate the tires from rubbing. Some have been lucky and haven't had to install aftermarket control arms as they claim not have any rubbing. Every vehicle is different, mostly because their alignment is within factory specs but its a range.
2. You may have to do the front liner mod which involves moving the front wheel well plastic liner forward and rescrewing.
LCA = Lower Control Arm
UCA = Upper Control Arm
Aftermarket control arms are usually recommended for lifts >2.5" and are designed with added caster to aid in retaining factory alignment specs when aftermarket lift kits are installed. This reduces the darting or wandering in the vehicle's steering when lift kits are installed and solves some rubbing issues for larger tires (up to a certain size of course).
Do your research into the different types of aftermarket control arms available. The ones that use uniballs give you more flexibility but can come at the sacrifice of noise and quicker wear.
The only other consideration is that any lift type modification will likely reduce the longevity of your vehicle. Notably, lifts over 2.5" puts increased stress on your CV joints as the angles are more acute. 50% of the people believe that a differential drop kit alleviates this stress, and the other 50% don't put any value on a diff drop kit :-).
jingksed is offline   Reply With QuoteReply With Quote
