View Single Post
Old 08-10-2016, 09:39 PM
Black798's Avatar
Black798 Black798 is offline
Real Name: Phoenix
Black798 is just really nice Black798 is just really nice Black798 is just really nice Black798 is just really nice
Black798's Avatar
Real Name: Phoenix
Black798's 98 limited build thread
Recent Pictures:
DSC_7136
IMG_1207
IMG_1300
Current Upgrades/Modifications:
Drivetrain /Engine/Performance
• K&N air filter (removed)
• AFE air filter
• Isr mod (removed)
• Safari Snorkel (removed)
• Dynomax super turbo 20 inch muffler (removed)
• Flowmaster Deltaflow 60 (removed)
• 3” turbo back stainless exhaust with vibrant muffler and resonator
• Transgo shift kit and glow shift trans temp gauge (Write up available Here)
• B&M 70268 Trans cooler with auxiliary fan
• Custom poly transmission mount
• Extended rear diff breather
• NWF ecocrawler dual case and triple stick
• Rear: TLC 9.5 diff with Nitro 5.29s and ARB RD142 air locker (nitro chromoly full float shafts)
• Rear: Custom built axle housing with full float ends 62” wms
• Front: TLC HP 8” with Nitro 5.29s and ARB RD132 air locker (rcv shafts)
• Front: Trail gear builder front axle 63” wms
• Second gen TRD supercharger (removed)
• MAPecu3 piggyback tuner (removed)
• GT3071 ball bearing turbo charger
• Haltech elite 2000 standalone ecu
• 650cc fuel injectors
• AEM wideband AFR gauge
• Glowshift boost and oil pressure gauges
Suspension
Front:
• Toytec bilstein/eibach coilovers (removed)
• King extended travel coilovers with 600 lb springs (removed)
• SPC upper control arms (removed)
• Currie Antirock sway bar
• Custom 3 link solid axle swap with 12x2.5 Fox dsc coilovers
• Fox 2.0 x 2.0 hydro bumps
• Fj80 steering box with hydro assist
• Custom built crossover highsteer
Rear:
• Dobinson C59-210v stock height progressive rate front coil for an 80 series (removed)
• LX450 7 wraps ≈ 3.5 inch lift (removed)
• OME 891 coils (removed)
• OME 906 coils with trim packer (removed)
• 4th gen rancho rs5000 shocks (removed)
• Fox 8 x 2.5 dsc coilovers mounted with a cantilever pivot. Strapped to 12” of travel
• Branik motorsports swaybar
• Custom 3 link suspension
Wheels and Tires
• Trail Ready HD17 beadlocks (4” backspacing)
• 37 x 12.50 Nitto trail grapplers
Lighting/Electrical:
• 4300k FXR 3 inch 35W hid retrofit
• Baja Designs LP6 spot lights
• Baja Designs Squadron Sport amber fog lights
• Extreme LED 5” scene lights for side lights
• Baja Designs LED Rock lights mounted to frame rails
• Extreme LED Stackerz for rear strobe dust lights/reverse
• Extreme LED pods for reverse lights
• Led taillights
• Full led conversion in cab and exterior lights
• ABS delete
• Big 3 mod
• Blue sea systems 12 circuit fuseblock with ignition relay and acrylic platform
• Fenix Industries switch controller
• 400 watt power inverter (mounted under drivers seat)
• Duralast Platinum H8 AGM battery
Interior
• 20% 3M Color Stable tint on front windows
• Sound deadening done with peel n seal and carpet padding throughout doors and floor
• 550 cord steering wheel wrap
• Milwaukee Packout mounted tool storage
• Weathertech front floor liners
Stereo/ Communication
• Cobra CB
• Upgraded sound system
Exterior /Armor
• 3M Clear Bra
• 3M 1080 anthracite carbon fiber vinyl on b pillars, gas tank lid, and rear spoiler
• Monstaliner medium quartz grey fender flares
• RSG sliders welded on
• Custom front bumper (powder coated satin black)
• Custom rear bumper (powder coated satin black)
• Custom tire swingout (powder coated satin black)
• Sherpa Equipment Matterhorn MK2 full length
Recovery
• 3in x 30ft Rugged Ridge tow strap
• 2in x 20ft Smittybilt tow strap
• 2 3/8in x 30ft ARB snatch strap
• 2in x 3ft tree saver
• x4 3/4in d rings
• x2 d ring hitch adapters
• 60in HiLift jack
• ARB ckma12 OBA setup
• ARB EZ deflator/Apex Design RPV valve stems
• Warn Evo 10 terminated with a factor 55 flatlink
• Tuff Stuff 10 ton snatch block
• Fire extinguisher
Trails completed
Montana
• Flathead Pass
• Brackett Creek and various other forest service roads
• North Meadow Creek
• Independence Pass
• Ringing Rocks
• Elkhorn Mine
Colorado
• Barbour Fork
• Yankee Hill
• Wheeler Lake
• Coney Flats
• Middle St. Vrain
• Chinamans Gulch
• Engineer Pass
• Black Bear Pass
• Imogene Pass
• Cinnamon Pass
• Poughkeepsie Gulch
• Tincup Pass
• Holy Cross
Utah
• Fins n Things
• Hells Revenge (including Hells Gate)
• Top of the World
• Poison Spider Mesa
• Gold Bar Rim
• 7 Mile Rim
• Gemini Bridges
• Moab Rim
• Pritchett Canyon
• Cliffhanger
• Steel Bender
Oregon
• Firebreak 5
• Crushers (upper/lower)
98 Limited - Solid Axle Swapped,Turboed,And On 37s - Build
Transgo Shit Kit Writeup - Click Here
Black798 is offline   Reply With QuoteReply With Quote
