After another day of disassembly removing the dash, wiring harness and finishing up cutting out that panel... we moved on to the bigger things, driveshaft and transmission:
Start of the day:
So I can get the harness back in place later:
Last thing: The crossmember frame horns. Still available from Toyota (same part between 2wd and 4wd - just welded in different spots!) only $118 each. Which means... they are coming off the 4WD frame:
Another day done. Beer drank... pool swam.
'99 4Runner SR5 Auto -
4WD swapped
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
