Originally Posted by JayRolla
A lot of times when a fuel pump is failing you can hit the tank and it will get that pump going. Old hammer trick. Works on stuck starters also.
Hah thanks, I'll remember that should it leave me stranded.
Originally Posted by TheDurk
Don't forget there is an in-tank filter before the pump. This puppy:
If there really is a pantload of gunk in the tank, that will be clogging up and starving your pump. For the record, I just changed mine (along with the pump) at 17+ years and 180k because I had the tank out, and it was pristine as was the tank (inside).
Yeah, I've read about those. Also not the only higher-mileage owner to say their tank was clean inside. Leaves me completely baffled, I know the fuel filter had an immediate and enormous benefit but I can't imagine changing something downstream of the fuel tank would have helped if the pump itself was starving over a clogged filter sock. And if the tank isn't starving for fuel and the original filter was clogged, how did it clog again so quickly?
I will say that I've probably run the tank low a lot.. I was under the assumption that inaccurate gas gauge and crappy tank venting caused me to fill up with a few gallons left in the tank after riding the gas light for a ways, always. Further reading just the other week suggested that the tank vent tube is too long and there's likely very little gas left when I'm filling ~14 gallons.
I've never taken my 4runner anywhere to be serviced, short of Discount Tire and Firestone for alignments, but I'd happily pay for a pro to get to the bottom of this. I had a brief taste of what a properly running 4runner feels like and it'd be so worth the bill to have that consistently, but I don't know what kind of troubleshooting a pro would do that I can't, just out of ideas.
