Originally Posted by TheDurk
The dash light is triggered by the position switch on the front diff (it's in a really nasty spot.) Sounds like that is your issue. The position switches on the TC tell the relay it is ok to engage the vacuum to the actuator on the diff. Then, when the diff engages the front shaft, the switch turns the light on.
Thank you, and you belong in the 3rd Gen Hall of Fame for your knowledge! I retraced the schematic you posted, and there it was - not sure how I missed it, but I would not known where to find it as I was too busy staring at the vacuum valves. I crawled under and checked it, and I believe it's the position switch in the front diff as you recommended. No continuity whether the 4WD was engaged or not. I'll get one on order this week.
