Traction control kicks in frequently when taking turns (lifted with 33” tires)
I lifted my truck almost immediately after buying a year ago, and noticed that sometimes when I took corners quickly (or making low speed, tight turns) the traction control would kick in. BEEP-BEEP.
It didn’t bother me too much, as it didn’t happen regularly, but I recently upgraded to 33” BFG A/T KO2’s, and it's
happening more frequently.
This happenes most often when entering a parking lot, which typically have a bit of an incline.
I did a Zero point calibration, and that didn’t make a difference.
Next, I noticed a bit of rubber on the front body mounts, and figured turning was causing the front tires to rub, slow down the wheel, and kick in the traction control. So, I did a body mount chop, but I still get a VSC kick-in when I corner.
I’m out of ideas, does anyone have any thoughts on troubleshooting this further? Any help appreciated.
2007 SR5, 6Cyl, 4WD - Sonoran Steel Lift, Pioneer AVH-X5700BHS Head Unit, HCF Delete
