Originally Posted by AssBurns
That's always an option. An will still keep the roll center about the same if you do both sides equally. I've noticed that most people have to extend their bump stops when they lift, so if you extend your bumps, you'll make more room for more of a lift bracket. This will increase your roll center quite a bit and really stiffen up the body roll. I guess it just depends on whether you've got the room to raise the panhard a few inches or if your stuck with only an inch.
I was running a 3" drop and sway bar in the rear but once I cut off the drop and made the lift, I also removed sway bars. It was a night and day difference in body roll. I haven't even put sway bars back on since the lift bracket.
Pictures of your lift bracket please.
