View Single Post
Old 11-12-2016, 02:41 AM
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
JZiggy's "Grown Up" 4Runner Build
Welcome to JZiggy's build / maintenance / sicmods thread! This is where I document all my projects and attempts to overthink simple repairs and upgrades. If that sounds like your thing then read on.
How the 4Runner sits today:
Engine:
First look under the valve cover
Second look, with valve adjustment info
Idler pulley bearing R&R
Fuel filter cut open
OEM mini-headers
A/C clutch bearing R&R
Water heater valve
Oil cooler and filter base overhaul
Oil pan reseal
UNI foam pre-filter install and servicing
PCV catch can install
Throttle cable lube and adjustment
Oil pump & harmonic balancer replacement
Walker exhaust system replacement
Rear main seal, crank sleeve, pilot bearing, flywheel, clutch
Intake refresh + OsideTiger upgraded fuel injectors
Compression test at 300k
Water pump & thermostat replacement
Drivetrain:
Rear axle bearings and seals
Marlin shifter bushings
Short shifter for W59 transmission
Trans and transfer shifter base upgrades
TrueTrac in the rear end
TrueTrac in the front
Manual hubs
Painted hub faces
Regear to Nitro 4.56 gears -- thanks Zuk!
Rear diff stud upgrade
OEM rear u-joint install
Replaced motor and trans mounts
Transmission rebuild
ARP manual hub studs
Suspension:
99 talls for the rear
Airlift 1000 helper springs (removed after lift)
Taco TRD front swaybar mod
Durobumps: front, rear, and differential brackets
Poly bushings in rear UCA, rear LCA, and panhard bar
Upper control arm OEM bushing replacement and lower OEM bushings
Dobinsons IMS 2" lift, JBA UCAs, extended links, PCK, etc.
Dobinson shock revalve for ride quality
Heavy Friction Metal Works spindle gusset install
ARP LBJ bolt upgrade (superseded by 01-02 OEM bolts)
01-02 LBJ OEM bolts and dust shields
Snowden rear lower shock protectors
Rokmen rear LCAs
LBJ Uniball conversion (Anonymous Fab)
Chassis:
Energy Suspension steering racking bushings
199mm TBU and rear wheel cylinders
OEM parking brake cable replacement
Transmission tunnel heat shield
Clutch and brake pedal pivot bushings
OEM body mount replacement
Parking brake bellcrank rebuild
OEM steering rack replacement
Bora wheel spacers and extended rear lug studs
Exterior:
SR5 skinny black flares - repaint and add gasket trim
SR5 front mudflaps
Windshield washer sprayer -- 2-hole to 3-hole upgrade / Honda Odyssey sprayer
96-98 Front bumper install with 99+ crash bar retrofit
Front Warn hitch install
Rocky Mtn Antero roof rack
Thule fairing install
Wade in-channel wind visors
Window tinting
Add a blinker bulb to the side marker housing
BX Built LED projector retrofit & high beam indicator fix
AVS hood deflector rivnut mounting upgrade
Paint repair
Painting the flares & bumper trim, mirrors, and cowl
Glass polishing
Interior:
BHicks 3D printed cupholder -- one of my very favorite sicmods
Rear seat child seat latch upgrade
Front seat upgrades -- rail extensions and memory foam
Rear console plug in the ashtray location
Phone holder modified Panavise bracket
Rear cargo mod -- awesome mod
Rear pressure vent and routing CB wire
Ceiling cargo hammock
Rear window switch install in cargo area
Cargo/sleeping/platform build
Door lock motor repair
Door check (door holder) mechanism repair
Spiker phone mount + Magmount
Sound deaden roof & re-glue roof support
Sound deadening of cabin (Siless 3-in-1)
Armor:
Stubbs sliders
Savage front skids
... And banging dents out of the skids
Rubber bumper for lift point on skid
Lil Skip gas tank skid
Freel Good Performance axle bash plate (rear diff armor)
Odds & Ends:
Bonus Spal e-fan install
Heated mirror retrofit
Truck-Bedz air mattress
Engine bay basket
CB mount and hatch bumper mod
Stabilizer foot upgrade to CB antenna mount
Subaru Forester gauge pack install (altimeter, compass, and thermometer)
Midland CB Radio bracket for transmission tunnel
Spiker Engineering hood struts
ARB awning brackets
Napa awning install and custom brackets
Napa awning support bracket
Napa awning horizontal strut stiffener
Power windows "camping mode" (operate without key-on)
Cabin air filter install
FourCam hatch vent cover
4th gen horn upgrade
Original post from 11-11-2016:
I picked up this 4Runner a couple of weeks ago and the projects are starting to happen.
Specs:
1999 4Runner Base model
3RZ-FE, 5 speed, 4WD
~230,000 miles
This truck was pretty much a dealer-serviced one-owner. No signs of being messed with at all. In the few tanks of gas I've driven it so far it's gotten 24-25 mpg and does not burn any oil that I can tell yet.
My old 4Runner, the college truck:
The new, "grown up" 4Runner:
(Pic edited badly to protect the innocent)
My goal is to keep this 4Runner a practical commuter that is reliable and gets good fuel economy, and do some sensible upgrades to improve its off-roadability as an occasional adventure rig. At least, that's my goal right now
JZiggy is offline   Reply With QuoteReply With Quote
