16. Using a second jack, slowly start to jack up the right of the slider. Be mindful of whole slider the entire time as it is moving.
17. Make sure the slider is pushed back against the frame when jacking it up. This will help ensure it makes it behind the KDSS lines.
18. Once the slider is up between the KDSS lines, remove the wood shims if they haven't already fallen out.
19. Don't forget about the gas tank skid. Make sure the bottom part of the slider is between the frame and the gas tank skid plate.
20. Slider is in.
21. Begin to attach all of the supplied 13mm bolts to the remaining holes.
