View Single Post
Old 08-04-2007, 08:49 PM
rando's Avatar
rando rando is offline
rando is on a distinguished road
rando's Avatar
Any ground will work. Check the schematic and pictures on the previous page. I didn't hook mine up at IC4 instead opting to insert it directly under the relays in the relay box. I soldered a piece of wire to each side of the diode and then jammed the other end of each wire directly into the relay spade terminals. Once the relays are reinstalled, it's secured.
The diode cathode goes to the load side of the circuit. The anode is connected to ground.
As shown in the schematic and pictures on the previous page, the diode cathode
Originally posted by chiefjhf
:awais: Rando, thanks for the awesome information. Just a dummy here who is not sure about the IC4 tap. If you tap D1 at the IC4 connector, where does the other end of the diode go to get it to ground?
Are you removing a spade terminal and inserting the diode between it and the connector? If so, which direction does the anode point to.
Sorry for being such an airhead.
rando is offline   Reply With QuoteReply With Quote
