Originally Posted by TheDurk
TheDurk's Rule #7 of 3G trouble-shooting: rear-end electrical weirdness is often due to broken or shorted wires in the harness between the top of the liftgate and the body. Slide that harness and look for any broken wires or missing insulation and repair.
That's a great point -- don't overlook the simple stuff. I'll certainly check that out.
But worth noting: The rear window motor gets power (as tested with a multi-meter) but seemingly not enough power to make it work. When I supply 12v from a battery directly to the motor, the window will go up and down.
The rear defogger also gets power when the dash switch is activated. But then of course loses power when the dash switch automatically deactivates 5-10 seconds later.
Thoughts?
