C4 FAB early 4th gen (03-05) Lo-Pro winch bumper install guide.
Hey everyone, here is our install guide for the 4th gen Lo-Pro winch bumper.
Tools needed:
-10mm wrench/socket
-12mm wrench/socket
-14mm wrench/socket
-19mm wrench/socket
-7/16" wrench/socket
-Flat blade screw driver
-Masking tape
-Die grinder or skillsaw to cut plastic bumper
Start by removing the plastic bumper cover from the 4runner. We did not get pictures of all the exact plastic clip and screw locations.
There are plastic clips located along the top edge of the bumper below the grille that need to be removed. Also remove all of the screws with 10mm head that attach the plastic fender liner to the plastic bumper cover. Be sure to remove the blinker and fog light bulbs with wire harness attached as well so the can hang from the vehicle and allow the bumper cover to come off.
There are two hidden screws at each outer corner of the bumper cover where it meets the fender. be sure to remove those as well before trying to remove the bumper cover.
Once all hardware is removed, firmly grasp the outer corner of the bumper by the fender and pull out and forward at the same time. The plastic cover will pop loose and come off of the vehicle.
Here are some pics of the screw locations after the bumper was removed.
Owner/Operator of C4 Fabrication. specializing in custom built Toyota off-road products. www.c4fabrication.com
