Originally posted by rook
The litgate consists of a door opener and a liftgate control module. If you have the time, inspect the mechanism, and test the electrical connections. It appears that the gate is getting a constant signal from the switch to open. Try closing the door and then immediately locking the truck, which should disable the rear liftgate switch. If it still unlocks itself, have a tech inspect the system.
Good luck.
Do you know where the signal switch that controls the ON/OFF of the lock module is located?
Thanks!
