Looking for a combo automatic lock and manual lock.
I hate how everything unlocks automatically.
Originally Posted by Sisente
Automatic door locking and unlocking functions
You can set the following automatic door locking and unlocking functions
(a) Locking linked with the shift position
All the side doors and back door are locked automatically when the automatic transmission selector level is moved out of the "P" position with the engine running (including ignition switch in the "ON" position) and all the side doors and back door are closed. This function is the default setting for new vehicles
(b) Unlocking linked with the shift position
All the side doors and back door are unlocked automatically when the automatic transmission selector lever is moved to the "P" position with the ignition switch in the "ON" position
(c) Locking linked with the vehicle speed
All the side doors and back door are locked automatically when the vehicle speed reaches 20km/h (12 mph) or higher. However, if any of the side doors and back door is unlocked during driving, this auto locking function will not operate until the unlocked door is opened once.
(d) Unlocking linked with opening the driver's door
All the side doors and back door are unlocked automatically when the driver's door is opened within 10 seconds after the ignition switch is turned from "ON" to the "ACC" or "LOCK" positions.
Setting the Functions
1. Close all the side doors and back door
2. Turn the ignition switch to the "ON" position
3. Within 10 seconds after the ignition switch is turned to the "ON" position;
To set function (a)
Push and hold the front of the power door lock switch for 5 seconds with the automatic transmission selector lever in the "P" position.
To set function (b)
Push and hold the rear of the power door lock switch for 5 seconds with the automatic transmission selector lever in the "P" position.
To set function (c)
Push and hold the front of the power door lock switch for 5 seconds with the automatic transmission selector lever in any position except "P".
To set function (d)
Push and hold the rear of the power door lock switch for 5 seconds with the automatic transmission selector lever in any position except "P".
All the side doors and back door are automatically lock and unlock when you release the power door lock switch. This indicates the function is set. If all the side doors and back door do not lock and unlock, the time the switch was held may have been too short or too long. Perform the procedure over again starting from step 1.
If you want to cancel a function, repeat the procedure. Each time you perform the, the function is set or cancelled.
